Content originally posted in LPCWare by OldisGold on Mon Jun 22 10:20:51 MST 2015
I am using LPC54102 Sensor processing solution evaluation kit and sensorhub bsx lite project from LPC Open. The example works fine but when I generated a hex file to check the code size it is over 350 kB. I want to optimize the code for size.
Question: Can I optimise the code for size by removing board.h files. ?
