Content originally posted in LPCWare by nkarakotas on Tue Jun 21 13:22:33 MST 2011
Quote: nkarakotas
HI,
Thanks for the reply. I set the value to what you have posted but when I debug it there is an interrupt always generated on the RIT. Even if RICOMPVAL is not equal to RICOUNTER.
For example RICOUNTER is 0x0f and the RICOUNTER is 0x61a7 it will interrupt.
Nick
Unless that is the timer running but was reset to 0x00. A few cycles until interrupt routine?
