lpcware
Need help in jumping from one address to other in LPC11U24's flash memory
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by saraswathi on Thu May 23 23:18:38 MST 2013
I have a product(LPC11U24) which has 2 hex files reside in flash. The first hex file is residing at the flash address 0x00000000 and second hex file is residing at the flash address 0x00004000. When power on the device, the first hex file starts executing and then I need to jump to the 2nd hex file from 1st hex file and start executing the 2nd hex file. I need to implement this in C code.
Can anyone guide me how to do this? What are the pre-conditions to be set before jumping from one location to other in flash? If any sample code is available, can you please share the same.
With regards
Saraswathi C
