Content originally posted in LPCWare by Ulysses on Mon Mar 29 16:58:38 MST 2010
[COLOR=black][FONT="]As per LPCXpresso kits:[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="] [/FONT][/COLOR]
[COLOR=black][FONT="]Q: Does NXP have or plan to design a seperate program - LPC flash programmer using LPC-LINK?[/FONT][/COLOR]
[COLOR=black][FONT="] Or use ISP/IAP only?[/FONT][/COLOR]
[COLOR=black][FONT="]Q: Do IAR or MDK support with LPC-LINK now? Or planed?[/FONT][/COLOR]
[COLOR=black][FONT="]Q: For LPC chip programming, the final released binary file is .axf or .hex?[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=blue][FONT="] [/FONT][/COLOR]
[COLOR=black][FONT="]Q: I checked some Make file, there may have commands to convert .axf create .hex file, am I right?[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="]Q: How to check final code/ram size for .axf file? [/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="] When I build released version for blinky example, I saw some basic information at the end of build process, its .Text size can reach 2.7KB, compare with its 8KB maxim flash space, is it OK? Looks like C run-time and system initial code use lot of code space.[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="]Q: For LPCXpresso IDE, how to Find/List keywords for all related files in whole project?[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="]Q: As recommendation, I need to close any code optimization for debugging, but when I enable code optimization later to build release version, how can I ensure any time critical design? [/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
[COLOR=black][FONT="] And, when I enable code size optimization and debug those code, what issue will be?[/FONT][/COLOR][COLOR=blue][FONT="][/FONT][/COLOR]
