lpcware
USB communications
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Andrew24 on Sat Mar 27 11:07:40 MST 2010
Hallo. I 'm developing a project on LPC1343 to acquire some data from a sensor, and then send the value through the USB to computer. What is the simplest way to do this? can i use the same usb cable for communications that i use to program and debug? or do i need to use the pins USB_DM, USB_DP?
