lpcware
lpc17xx cmsis driver for lpcxpresso board
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by alpha on Mon Jun 11 01:59:19 MST 2012
Is the lpc17xx.cmsis.driver.library fully compatible for lpcxpresso board?
I found at lpc17xx_emac.c/.h :
#ifdef MCB_LPC_1768
/* DP83848C PHY definition ------------------------------------------------------------ */
#elif defined(IAR_LPC_1768)
/* KSZ8721BL PHY definition ------------------------------------------------------------ */
The newer lpcxpresso is using the LAN8720 but it doesnt seem to be found on the lpc17xx_emac.h header. or is it same as KSZ8721?
