External makefile project debugging problem
lpcware
Content originally posted in LPCWare by ArtjomGromak on Fri Mar 02 15:32:24 MST 2012
Hi!
I use LPCXpresso for debug my program(as toolchain I use YAGARTO). But I want use LPCXpresso for editing and building too.
I import the existing project in IDE as Existing makefile project. Editing and build work. But I can't start debug. When I try create launch configuration LPCXpresso show message: No binaries found.
But elf (or axf) files exists.
[ATTACH]685[/ATTACH]
What I do wrong?
Thanks.
maddin
I have exactly the same problem with MCUXpresso 10.1.1 606.
Can build the imported makefile project, axf exists but when try to create a launch configuration: "no binaries found.."
Any help would be appreciated. Thanks
