Content originally posted in LPCWare by xiaoqing025 on Fri Jul 26 00:25:34 MST 2013
The below is my POST method string, my question is when the Content-Length is bigger than standard IP packet length, whether the information could be sent by many times, e.g.: connect()+send()+send()+...+close(), connect(), send() and close() are standard socket of TCP/IP. Do the "Connection:" need be modified as "Keep-Alive" ?
"POST /ems/php/emud.php HTTP/1.0\r\n"
"Host: 192.168.52.69\r\n"
"Connection: close\r\n"
"Content-Type: application/x-www-form-urlencoded\r\n"
"Content-Length: 10000\r\n"
"\r\n"
"information=xxxxxxxxxxxxxxxxx"
Thanks so much!
