Content originally posted in LPCWare by tiziano.annoni on Fri Aug 03 02:30:30 MST 2012 Dear all, I'm using LPCXpresso 4.2.3.292 with LPC1857. I've 2 questions: - from device list supported by LPCXpresso, I can see also Flash parts like LPC1857. I'm able to correctly program/debug it with code running from external flash, but I'm not able to program the code in internal Flash. Is internal Flash of LPC18xx / LPC43xx supported or should I wait for next sw release? - I'm using lpc open platform [link] and an MCB1857 board, but programming of external memory is extremely slow. How could I improuve the speed? Thank you, BR Tiziano
Content originally posted in LPCWare by tiziano.annoni on Fri Aug 31 00:21:30 MST 2012 Dear Support, do you have a planned date (also a rough idea could help me) for next release of LPCXpresso? Thank you, Regards, Tiziano
Content originally posted in LPCWare by jgorsk on Mon Aug 06 05:51:29 MST 2012 Does it mean that the flash programming isn't working in LPCXpresso 4.2.3 for the LPC43xx flash based parts? When is the next release of LPCXpresso expected?
Content originally posted in LPCWare by CodeRedSupport on Mon Aug 06 03:20:16 MST 2012 LPC18/43 internal flash support is not included in LPCXpresso 4.2.3, but will be included in the next release.
