Content originally posted in LPCWare by navman on Thu Jul 07 23:57:10 MST 2011
Rob65, Thanks for your detailed analysis. We are doing a highly time-sensitive application so even if we can save 100ns, it would make a big difference. I've contacted NXP for support and waiting for their response.
The application actually is to read a high speed 16bit-ADC which has a 8-bit parallel output & a data ready pin. The data ready pin toggles every 500ns & we need to be able to read a high byte at rising edge and a low byte at the falling edge then store the bytes into a buffer for processing later. Leave alone the buffering, we are struggling to even try and read the data!
