int main (void) { /* Initialize 32-bits timer 0 */ init_timer32(0, TIME_INTERVAL); enable_timer32(0); /* Initialize the PWM in timer32_1 enabling match0 output */ init_timer32PWM(1, period, MATCH0); setMatch_timer32PWM (1, 0, period/4); enable_timer32(1); /* Initialize the PWM in timer16_1 enabling match1 output */ init_timer16PWM(1, period, MATCH1, 0); setMatch_timer16PWM (1, 1, period/8); enable_timer16(1); /* Enable AHB clock to the GPIO domain. */ LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6); /* Set port 2_0 to output */ GPIOSetDir( 2, 0, 1 ); while (1) /* Loop forever */ { /* I/O configuration and LED setting pending. */ if ( (timer32_0_counter > 0) && (timer32_0_counter <= 50) ) { GPIOSetValue( 2, 0, 0 ); } if ( (timer32_0_counter > 50) && (timer32_0_counter <= 100) ) { GPIOSetValue( 2, 0, 1 ); } else while ( timer32_0_counter < 100 ); //wait for timer32_0_counter = 0; } } |
... init_timer32PWM(1, period, MATCH0); setMatch_timer32PWM (1, 0, [color=#f00]period/4[/color]); ... init_timer16PWM(1, period, MATCH1, 0); setMatch_timer16PWM (1, 1, [color=#f00]period/8[/color]); ...} |
