lpcware
stuck in WD interrupt
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by 12345 on Mon Jul 11 20:30:57 MST 2011
Program stuck in WD interrupt handler!
  How can I jump out from the WD interrupt handler?
void WDTInit( void )
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<15);
  wdt_counter = 0;
  /* Enable the WDT Interrupt */
  NVIC_EnableIRQ(WDT_IRQn);
  LPC_WDT->TC = WDT_FEED_VALUE;//timer constant register 1.576Sec /* once WDEN is set, the WDT will start after feeding */
  LPC_WDT->MOD=0x00;
  LPC_WDT->MOD=WDEN;
  LPC_WDT->FEED = 0xAA;/* Feeding sequence */
  LPC_WDT->FEED = 0x55;
  return;
void WDT_IRQHandler(void)
  //UARTSendOne(0x13);
  if (LoadCG==0)
  NVIC_SystemReset();
   NVIC_DisableIRQ(WDT_IRQn);// Disable the watchdog- interrupt flag cannot
  // be cleared except by reset
   LPC_WDT->MOD &= ~WDTOF;/* clear the time-out interrupt flag */
                                //reset to zero watchdog timeout flag//
   LPC_WDT->MOD &= ~WDINT;/* clear the time-out flag and interrupt flag */
   //wdt_counter++;
   //WDTFeed();
