Content originally posted in LPCWare by CodeRedSupport on Wed Jun 26 00:28:55 MST 2013
Plenty of example code is available which uses delays - typically by using the Systick timer peripheral.
I suggest that you look at the examples supplied in LPCXpresso for the actual MCU that you are using.
CodeRedSupport
