Content originally posted in LPCWare by duprein on Thu Jun 27 13:13:38 MST 2013
Hi All,
I'm currently using LPC1114 and LPCxpresso LPC-link as a debugger.
The question is: is there a possibility to connect to the target via SWD during operation without resetting/flashing it?
I can't find this in LPCxpresso suite out-of-box, just a debug session with flashing first. I've played around a little bit and found that if I'm connecting via GDB, SWD enabled and SWD pins active (not other functions enabled), then I could reach target in a text mode. I will dig a little bit around, but maybe could somebody advise me a proven way to proceed?
Thanks in advance!
