lpcware
need an advice on using sd card
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by dragilla on Wed Nov 23 03:38:24 MST 2011
Hey,
I want to use sd card in project to:
a) read some configuration data (best would be from a text file)
b) save data regularly from my 100hz loop (I want to save data say every 5 iterations of my loop)
How long do you think will it take to write 100-200 bytes of data to an sd card directly (no fs)? How much longer will it take using petit fatfs for example?
Should I write the data from inside my loop or should I use interrupt maybe and write my data onto sd in a "free" time?
If you have some examples of reading/writing to an sd card (with or without fs) using cmsis 1.3 they are greatly welcome here :)
regards,
Luke
