lpcware
Did the "variables" tab change?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by micrio on Sat Dec 01 12:10:57 MST 2012
The operation of the "Variables" tab seems to have changed with version 5.   It now shows the variables local to the function that you are in, which is nice.   It does not let you select global variables like you could in version 4.   In version 5 the eyeglass (Add Global Variables) and the two delete icons are grayed out.   In version 4 they worked as expected.
I did export my project from version 4 as a zip file and imported it into version 5.   My project works properly in version 5 except for the "variables" tab.   Is there something that I need to do?
Pete.
