lpcware
LPCXpresso V7.00 mcu settings bugs
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by vostro1000 on Thu Mar 06 10:22:42 MST 2014
Hi! I found a bug in mcu settings with LPCXpresso  V7.00...
If you go to project properties and go to "MCU settings"  and do edit memory regions... Make the changes that you want like split a ram region of the MCU that you use in your project...
Press ok button...
Now go again to : properties and "MCU settings" and you will see it does not save your changes!!!   :(
But if in the first step if after you changes muc settings you go to another field and after press "ok" it will save your settings   :O
