Content originally posted in LPCWare by MikeHalo on Tue Nov 02 03:06:39 MST 2010 Hi there,
I have been using my LPCXpresso demo board for a couple of days with no problem (other than a windows error when I connected to the LPC-link, but that didn't seem to affect anything).
Yesterday though, the thing stopped working. I now get the error message: "LPCXpresso Debug Driver v2.0 (Aug 31 2010 23:36:44) Looked for chip XML file in C:/nxp/lpcxpresso_3.5/bin/LPC1114/301.xml Looked for vendor directory XML file in C:/nxp/lpcxpresso_3.5/bin/nxp_directory.xml Found generic directory XML file in C:/nxp/lpcxpresso_3.5/bin/crt_directory.xml 02: Failed on connect: Ee(02). Not connected to emulator. Emu(0): Connected. Was: None. DpID: EDB6. Info: T1S6RGRIA"
I have tried the board on a similar machine with the same results (without the windows error).
I'm using Windows XP, LPCXpresso v3.5.0 [Build 206] [01/09/2010],
Have I corrupted the emulator code? Have I damaged the board?
Content originally posted in LPCWare by carlvanwormer on Mon Nov 08 10:52:52 MST 2010 [B]This may be related to a problem that we had. Search for the thread that contains:[/B] [B]Cannot provide power to DAP bus - one solution[/B] Good Luck!
Content originally posted in LPCWare by NXP_Europe on Thu Nov 04 04:54:00 MST 2010 Hello Mike, see for additional info the User Manual. How the ISP works.
