Content originally posted in LPCWare by rlavine on Thu Nov 11 14:40:34 MST 2010
I've got a mess of pulses to make and they need to be in synch, I searched the forums, the net and the data sheets and found no answer. I want all of the counters to reset together and then be controlled by the preset registers. I thought I might be able to do this with the power controls as they remove the clock from the timers but I don't think I can write the registers in this condition without a clock?
I know I should just try it, but it seems I can't be the only one wanting all the counters in sync?
