Content originally posted in LPCWare by CodeRedSupport on Mon Apr 29 08:27:15 MST 2013
No problems here. Downloaded and installed Ubuntu 13.04 64 bit bit, installed LPCXpresso and activated, and everything worked as expected, including activation.
Did you install the 32 bit libraries as detailed in the release notes and getting started guide?
