Content originally posted in LPCWare by CodeRedSupport on Wed May 01 02:05:00 MST 2013 LPCXpresso v5.2.4 has been released. Changes in this release include:
* Fixed problem in managed linker script that affects projects with 'old-style' startup code * Fixed missing images in Red State Getting Started PDF * Fixed memory configuration editor * Added 'Refresh' button to MCU selection to refresh internal caches [INDENT]Allows easy fixing of missing flash driver problem seen by some customers with LPCXpresso 5.2.2. For more details see http://support.code-red-tech.com/CodeRedWiki/FlashDriverNotFound522[/INDENT] * Fixed problem with the LPC11/12/13 flash driver for 1KB SRAM parts overflowing available SRAM. * Fixed potential mass erase problem with the LPC17xx/407x_8x flash drivers for parts with less than 512KB flash
