Content originally posted in LPCWare by DiamondS on Wed Apr 18 06:45:55 MST 2012 Thanks. It helped. Using a 96 MHz clock is not working, so i use 64MHz and everyhing is fine with 1Mb baudrate.
Content originally posted in LPCWare by gbm on Tue Apr 17 01:18:32 MST 2012 Yes, but your system clock must be a multiple of 16 MHz (otherwise you will need to use fractional divider on UART) - 96 MHz should be the right choice.
