License Check Failure
lpcware
Content originally posted in LPCWare by mrodsilva on Thu Jan 21 10:11:34 MST 2010
I'm getting an License Check Failure error dialog.
The console shows the following message:
LPCXpresso Debug Driver v2.0 (Dec 10 2009 17:53:22)
Looked for chip XML file in C:/nxp/lpcxpresso_3.1/bin/LPC1343.xml
Looked for vendor directory XML file in C:/nxp/lpcxpresso_3.1/bin/nxp_directory.xml
Found generic directory XML file in C:/nxp/lpcxpresso_3.1/bin/crt_directory.xml
NXP: LPC1343  Part ID: 3D00002B
License check failure (CheckLicense)
Does anyone knows what is going wrong?
Marcelo
Original Attachment has been moved to: 1100050_timertest.txt.zip
lpcware
Content originally posted in LPCWare by mrodsilva on Thu Jan 21 12:21:24 MST 2010
Upgrade to the newest and it is working.:)
thanks
lpcware
Content originally posted in LPCWare by mrodsilva on Thu Jan 21 11:29:43 MST 2010
I will get the newest...
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Jan 21 11:27:28 MST 2010
There have been two releases since 3.1.2.
- v3.1.4  (released in late December) fixes the issue you are reporting
- v3.2.1 (released yesterday) improves performance on Windows XP and improves some Peripheral views
So, no, 3.1.2 is not the latest!
lpcware
Content originally posted in LPCWare by mrodsilva on Thu Jan 21 10:50:37 MST 2010
Just to mention:
I do have:
1 - LPCXpresso LPC1343 Rev A
1 - RDB1768
I have both (LPCXpresso IDE and Code Suite 2 - Eval) intalled
I can run and debug programs using RDB1768 and Code Suite 2.
I have the problem when using LPCXpresso IDE with LPC1343
lpcware
Content originally posted in LPCWare by mrodsilva on Thu Jan 21 10:46:41 MST 2010
I'm using the following version:
LPCXpresso:
Build id: 2009-12-11 (v3.1.2)
Isn't this the most recent?
thanks
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Jan 21 10:43:28 MST 2010
It looks like you are using an out-of-date version of LPCXpresso (v3.1.2?).
You can download the latest version from Downloads area of the lpcxpresso.code-red-tech.com.
