Content originally posted in LPCWare by vasanth on Sat Dec 29 08:23:30 MST 2012 No. You missed out power consumed by MCU peripherals, Clock circuitry and PLL...:mad: Calculating from datasheet is not recommended. Use a device such as a multimeter to find the total current consumed by your MCU from your board. Then, this simple formula P = V x I is all you need. :)
