Content originally posted in LPCWare by lpcxpresso-support on Wed Mar 12 09:47:04 MST 2014 There is an issue in LPCXpresso 7.0.2 that prevents the C/C++ Indexer from running. The C/C++ indexer uses the parser to create a database of your source and header files that provides the basis for C/C++ search, navigation features and parts of content assist.
This issue can be resolved by adding the "-index" option on a separate line at the start of the lpcxpresso.ini file. [list] [*]On Windows and Linux, this file can be found in: [list] [*]{install_dir}/lpcxpresso/lpcxpresso.ini [/list] [*]On Mac, this file is inside the lpcxpresso application bundle: [list] [*]{install_dir}/lpcxpresso/lpcxpresso.app/Contents/MacOS/lpcxpresso.ini [/list] [/list]
