Content originally posted in LPCWare by Sal Ammoniac on Thu Nov 20 23:20:11 MST 2014
When I click the "Build project" icon (the hammer), it compiles all of my C and assembly files. If I then edit one of the C files and do another build, it goes and compiles everything again.
Why does it do this? I would expect that after I changed one of the C files after the first build the second build would just compile the file I changed, not all of the files again.
It's acting like "Build project" is really "Clean project + Build project".
Is there a configuration item that I have set incorrectly that's causing this behavior?
LPCXpresso 7.5.0
