Content originally posted in LPCWare by mars4zhu on Sun Jan 10 00:44:13 MST 2010
since the usb port is not enough for my notebook, I have to use a 4 port usb hub, and when i link the lpcXpresso to the computer through the usb hub, the driver installed successfully, but when push the "debug "blinky" ", LPC-lint Initializing windows appears but for a little long time it said initialzing time out
, without the hub, it works ok, but I have to use touchpad otherthan mouse to debug, so how to solve that problem?
*** DFU LOG FILE ***
Creation Time : C:\Users\mars4zhu\AppData\Local\Temp\dfuApp2414309398569513457.log
Open Device
Get Device Descriptor successful
Get Configuration Descriptor successful
DFU Get Status successful
---> DFUStatus: No error condition present.
---> DFUState: Device is operating in the DFU mode and is waiting for requests.
Device Descriptor
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40
idVendor: 0x0471
idProduct: 0xdf55
bcdDevice: 0x0001
iManufacturer: 0x00
iProduct: 0x00
iSerialNumber: 0x00
bNumConfigurations: 0x01
DFU Get State successful
Download Block Nb 0 (2048 Bytes)
---> DFUState: Device has received a block and is waiting for the host to solicit the status via DFU_GETSTATUS.
---> DFUState: Device is processing a download operation. Expecting DFU_DNLOAD requests.
Download Block Nb 1 (2048 Bytes)
Download Block Nb 2 (2048 Bytes)
Download Block Nb 3 (2048 Bytes)
Download Block Nb 4 (2048 Bytes)
Download Block Nb 5 (2048 Bytes)
Download Block Nb 6 (2048 Bytes)
Download Block Nb 7 (2048 Bytes)
Download Block Nb 8 (2048 Bytes)
Download Block Nb 9 (2048 Bytes)
Download Block Nb 10 (2048 Bytes)
Download Block Nb 11 (2048 Bytes)
Download Block Nb 12 (2048 Bytes)
Download Block Nb 13 (2048 Bytes)
Download Block Nb 14 (2048 Bytes)
Download Block Nb 15 (2048 Bytes)
Download Block Nb 16 (2048 Bytes)
Download Block Nb 17 (2048 Bytes)
Download Block Nb 18 (520 Bytes)
Download Block Nb 19 (0 Bytes)
---> DFUState: Device has received the final block of firmware from the host and is waiting for receipt of DFU_GETSTATUS to begin the Manifestation phase; or device has completed the Manifestation phase and is waiting for receipt of DFU_GETSTATUS. (Devices that can enter this state after the Manifestation phase set bmAttributes bit bitManifestationTolerant to 1.)
---> DFUState: Device has programmed its memories and is waiting for a USB reset or a power on reset. (Devices that must enter this state clear bitManifestationTolerant to 0.)
Device Reset after Download successful
Close Device
*** END OF FILE ***
