Content originally posted in LPCWare by celephicus on Wed May 30 19:49:22 MST 2012
Greetings,
We all know that variables declared static with no explicit initialization are implicitly set to zero by the start up code. Now, how do I declare a static variable that is NOT so initialized? I need this to keep state during a watchdog reset so that I can ascertain which thread blocked and caused the reset.
Hopefully this can be done without linker trickery.
