772,858 2-list-thread-groups
772,858 2^done,groups=[{id="i1",type="process"}]
772,858 (gdb)
776,340 3-gdb-version
776,341 ~"GNU gdb (GNU Tools for ARM Embedded Processors) 7.8.0.20150304-cvs\n"
776,341 ~"Copyright (C) 2014 Free Software Foundation, Inc.\n"
776,341 ~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"
776,341 ~"This GDB was configured as \"--host=i686-linux-gnu --target=arm-none-eabi\".\nType \"show configuration\" for configuration details."
776,341 ~"\nFor bug reporting instructions, please see:\n"
776,342 ~"<http://www.gnu.org/software/gdb/bugs/>.\n"
776,342 ~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"
776,342 ~"For help, type \"help\".\n"
776,342 ~"Type \"apropos word\" to search for commands related to \"word\".\n"
776,342 3^done
776,361 (gdb)
776,362 4-environment-cd /home/shane/source/firmware
776,363 4^done
776,363 (gdb)
776,363 5-gdb-set breakpoint pending on
776,363 5^done
776,363 (gdb)
776,364 6-enable-pretty-printing
776,364 6^done
776,364 (gdb)
776,364 7-gdb-set python print-stack none
776,364 7^done
776,365 (gdb)
776,365 8-gdb-set print object on
776,365 8^done
776,365 (gdb)
776,366 9-gdb-set print sevenbit-strings on
776,366 9^done
776,366 (gdb)
776,366 10-gdb-set charset ISO-8859-1
776,367 10^done
776,367 (gdb)
776,367 11source .gdbinit
776,368 &"source .gdbinit\n"
776,617 &"Ni: LPCXpresso RedlinkMulti Driver v7.8 (May 28 2015 03:21:31 - crt_emu_cm_redlink build 388)\n"
776,617 &"Pc: ( 0) Reading remote configuration\n"
776,617 &"Pc: ( 5) Remote configuration complete\n"
776,617 &"Nc: Probe Firmware: LPC-LINK2 CMSIS-DAP V5.112 (NXP Semiconductors)\n"
776,618 &"Nc: VID:PID: 1FC9:0090\n"
776,618 &"Nc: USB Path: /dev/hidraw5\n"
776,618 &"Wc: Vector catch on SYSRESETREQ signal\n"
776,618 &"Pc: ( 30) Emulator Connected\n"
776,618 &"Pc: ( 40) Debug Halt\n"
776,618 &"Pc: ( 50) CPU ID\n"
776,618 &"Nc: Emu(0): Conn&Reset. DpID: 0BC11477. CpuID: 410CC600. Info: (null)\n"
776,618 &"Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Enabled.\n"
776,618 &"Nc: loaded v.2 On-chip Flash Memory LPC11U6x_128K.cfx\n"
776,618 &"Nc: image 'LPC11U6x/11E6x (128K Flash) May 21 2015 09:32:48'\n"
776,618 &"Pc: ( 65) Chip Setup Complete\n"
776,618 &"Nt: Connected: was_reset=true. was_stopped=false\n"
776,618 &"Cr:v LPCXpresso Free License - Download limit is 256K\n"
776,618 &"Pc: ( 70) License Check Complete\n"
776,618 &"Pc: ( 85) Registered Semihost Handler\n"
776,618 &"Pc: (100) Target Ready\n"
776,618 =thread-group-started,id="i1",pid="42000"
776,618 =thread-created,id="1",group-id="i1"
776,619 12-list-thread-groups --available
776,620 13-list-thread-groups
776,636 ~"0x00000244 in ?? ()\n"
776,636 *stopped,frame={addr="0x00000244",func="??",args=[]},thread-id="1",stopped-threads="all"
776,636 11^done
776,636 (gdb)
776,637 12^error,msg="Can not fetch data now."
776,637 (gdb)
776,637 13^done,groups=[{id="i1",type="process",pid="42000"}]
776,637 (gdb)
776,638 14-gdb-set auto-solib-add on
776,638 14^done
776,638 (gdb)
776,646 15-file-exec-and-symbols --thread-group i1 /home/shane/source/firmware/Release/firmware.axf
776,651 16-list-thread-groups i1
776,681 15^done
776,681 (gdb)
776,682 16^done,threads=[{id="1",target-id="Thread <main>",frame={level="0",addr="0x00000244",func="Chip_Clock_GetWDTRate",args=[{name="reg",value="268450532"}],file="../src/main/cpp/external/lpcopen-11u6x/clock_11u6x.c",fullname="/home/shane/source/firmware/src/main/cpp/external/lpcopen-11u6x/clock_11u6x.c",line="71"},state="stopped"}]
776,682 (gdb)
776,686 17-interpreter-exec console "set remotetimeout 60000"
776,687 =cmd-param-changed,param="remotetimeout",value="60000"
776,687 17^done
776,687 (gdb)
776,889 18-target-select extended-remote | crt_emu_cm_redlink -msg-port=37006 -g -mi -2 -pLPC11U67 -vendor=NXP -vc -reset= -ProbeHandle=1 -CoreIndex=0 -flash-driver=LPC11U6x_128K.cfx
776,889 19-stack-info-depth --thread 1 11
776,889 =thread-exited,id="1",group-id="i1"
776,889 =thread-group-exited,id="i1"
776,893 20-gdb-exit
777,006 =thread-group-started,id="i1",pid="42000"
777,006 =thread-created,id="1",group-id="i1"
777,006 21-list-thread-groups --available
777,017 ~"Chip_Clock_GetWDTRate (reg=268450532) at ../src/main/cpp/external/lpcopen-11u6x/clock_11u6x.c:71\n"
777,017 ~"71\t\tclk = (CHIP_WDTLFO_OSC_T) ((reg >> 5) & 0xF);\n"
777,017 *stopped,frame={addr="0x00000244",func="Chip_Clock_GetWDTRate",args=[{name="reg",value="268450532"}],file="../src/main/cpp/external/lpcopen-11u6x/clock_11u6x.c",fullname="/home/shane/source/firmware/src/main/cpp/external/lpcopen-11u6x/clock_11u6x.c",line="71"},thread-id="1",stopped-threads="all"
777,018 18^connected
777,018 (gdb)
777,090 19^done,depth="5"
777,090 (gdb)
777,090 =thread-exited,id="1",group-id="i1"
777,090 =thread-group-exited,id="i1"
