lpcware
8bit variabile
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by blasiis on Fri May 25 01:11:23 MST 2012
I use LPC1758
I have change the lpcxpresso from version .3.6.2 to 4.2.2
The problem is with scructure like this:
typedef struct
    uint8_t  var1;
    uint8_t  var2;
    uint8_t  var3;
    uint8_t  var4;
    uint8_t  var5;
} MY_STRUCT_T;
This structure with LPCXPRESSO 3.6.2 is large 5 byte, with LPCXpresso 4.2.2 is large 8 byte !!!
I cannot find the linker option for packet this struct.
Where is ?
