lpcware
16*2 lcd display not working with LPC1769
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Irappa on Wed Sep 04 23:33:29 MST 2013
i have tried many times to interface 16*2 lcd display with LPC1769 but it was not working.
Please find the below code or if you have source code please send it to iru1688@gmail.com.
Author      :
Version     :
Copyright   : Copyright (C)
Description : main definition
#ifdef __USE_CMSIS
#include "LPC17xx.h"
#include "type.h"
#endif
#include "lcd.h"
****1111
  Function Name : delay()
  Description :This function suspends the tasks for specified ticks.
  Input :  ticks:no of ticks in multiple of 1 usec
            task: task to be suspended
  Output : void
  Note :
void delay(int count)
  int j=0,i=0;
  for(j=0;j<count;j++)
    /* At 60Mhz, the below loop introduces
    delay of 10 us */
    for(i=0;i<35;i++);
  Function Name :wait_lcd()
  Description   :
  Input         :
  Output        :Void
  Note          :
void wait_lcd( void )
  LCD_DATA_DIR &= ~LCD_DATA_MASK;
  LCD_CTRL_CLR |=  LCDRS;
  LCD_CTRL_SET |=  LCDRW |LCDEN;
  while(LPC_GPIO0->FIOPIN & LCD_BUSY_FLAG);/* wait for busy flag to become low */
  LCD_CTRL_CLR |= LCDEN | LCDRW;
  LCD_DATA_DIR |= LCD_DATA_MASK;
  delay(100);
  Function Name :lcd_command_write()
  Description   :
  Input         :
  Output        :Void
  Note          :
#define DATA_POS 19
#define DELAY_COUNT 100
void lcd_command_write( unsigned char command )
  unsigned char temp=0;
  unsigned int temp1=0;
  temp=command;
  temp=(temp>>4)&0x0F;
  temp1=(temp<<DATA_POS)&LCD_DATA_MASK;
  LCD_CTRL_CLR = LCDRS;
  LCD_CTRL_SET = LCDEN;
  LCD_DATA_CLR = LCD_DATA_MASK;
  LCD_DATA_SET = temp1;
  //delay(DELAY_COUNT);
  LCD_CTRL_CLR = LCDEN;
  temp=command;
  temp&=0x0F;
  delay(DELAY_COUNT);
  LCD_CTRL_SET |= LCDEN;
  LCD_CTRL_CLR |= LCDEN;
  wait_lcd();
  Function Name :set_lcd_port_output()
  Description   :
  Input         :
  Output        :Void
  Note          :
void set_lcd_port_output( void )
  LCD_CTRL_DIR |= ( LCDEN | LCDRS | LCDRW | LCD_BACKLIGHT );
  LCD_CTRL_CLR |= ( LCDEN | LCDRS | LCDRW | LCD_BACKLIGHT );
  Function Name :lcd_clear()
  Description   :
  Input         :
  Output        :Void
  Note          :
void lcd_clear( void)
  lcd_command_write( 0x01 );
  Function Name :lcd_gotoxy()
  Description   :
  Input         :
  Output        :Void
  Note          :
int lcd_gotoxy( unsigned int x, unsigned int y)
  int retval = 0;
  if( (x > 1) && (y > 15) )
    retval = -1;
  } else {
  if( x == 0 )
    lcd_command_write( 0x80 + y );/* command - position cursor at 0x00 (0x80 + 0x00 ) */
  } else if( x==1 ){
    lcd_command_write( 0xC0 + y );/* command - position cursor at 0x40 (0x80 + 0x00 ) */
   return retval;
  Function Name :lcd_data_write()
  Description   :
  Input         :
  Output        :Void
  Note          :
void lcd_data_write( unsigned char data )
  temp=data;
  LCD_CTRL_SET |= LCDEN|LCDRS;
  temp=data;
  temp&=0x0F;
  wait_lcd();
  Function Name :lcd_putchar()
  Description   :
  Input         :
  Output        :Void
  Note          :
void lcd_putchar( int c )
  lcd_data_write( c );
  Function Name :lcd_putstring()
  Description   :
  Input         :
  Output        :Void
  Note          :
void lcd_putstring( unsigned char line, char *string )
  unsigned char len = MAX_CHAR_IN_ONE_LINE;
  lcd_gotoxy( line, 0 );
  while(*string != '\0' && len--)
    lcd_putchar( *string );
    string++;
  Function Name :lcd_backlight_on()
  Description   :
  Input         :
  Output        :Void
  Note          :
void lcd_backlight_on()
  LCD_BACK_LIGHT_DIR |= LCD_BACKLIGHT;
  LCD_BACK_LIGHT_SET |= LCD_BACKLIGHT;
Function Name : turn_off_lcd_back_light()
Description   :
Input         :
Output        : Void
Note          :
void lcd_backlight_off(void)
   LCD_BACK_LIGHT_CLR |= LCD_BACKLIGHT;
  Function Name :init_lcd()
  Description   :
  Input         :
  Output        :Void
  Note          :
void init_lcd( void )
  set_lcd_port_output();
  lcd_command_write(0x28);     /*   4-bit interface, two line, 5X7 dots.        */
//  lcd_clear() ;                /*   LCD clear                                   */
  lcd_command_write(0x02);     /*   cursor home                                 */
  lcd_command_write(0x06);     /*   cursor move direction                       */
  lcd_command_write(0x0C) ;    /*   display on      */
  lcd_gotoxy(0, 0);
  lcd_clear();
Please help me.
