lpcware
How to use CYCLE in Core Registers?
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by jnd on Thu Mar 11 16:10:48 MST 2010
I'd like to count cycles for one loop and haven't figured how could I do it. I found these two rows in Core Registers tab which sound promising:
CYCLE indicates the number of cycles executed since reset
CYCLEDELTA indicates the number of cycles executed since the last start
But they never change. I tried setting them to something but that didn't help. Is there any way to use them? How to display elapsed cycles of executed code in the debugger? I had idea about using timer but found it runs freely even when the execution is suspended.
