Content originally posted in LPCWare by CodeRedSupport on Fri Mar 12 12:23:15 MST 2010
The `#pragma GCC optimize' pragma is not implemented in GCC versions earlier than 4.4. LPCXpresso uses 4.3.3.
You can use function attributes to set various attributes, although, again, optimize is not supported in this version.
