lpcware
No emulator/board available
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by reLinux on Fri May 18 12:29:22 MST 2012
Hello all,
I installed LPCXpresso successfully on my Ubuntu 10.04 some time ago and was able to debug programs on my LPC11C24. Now, after several weeks and Ubuntu-Updates that does no longer work. I always get the "No emulator/board available" message.
I tried different USB ports and cables. I also tried to pull P0_1 low to get into ISP mode without success.
Following http://support.code-red-tech.com/CodeRedWiki/LPCLinkDiagnostics gives the following results:
$ lsusb
Bus 001 Device 050: ID 0471:df55 Philips
$ ./dfu-util -l
dfu-util - (C) 2007-2008 by OpenMoko Inc.
This program is Free Software and has ABSOLUTELY NO WARRANTY
Found Runtime: [0x0471:0xdf55] devnum=50, cfg=0, intf=0, alt=0, name="UNDEFINED"
$ ./dfu-util -d 0x471:0xdf55 -c 0 -t 2048 -R -D LPCXpressoWIN.enc
Opening USB Device 0x0471:0xdf55...
Claiming USB DFU Runtime Interface...
Determining device status: state = dfuIDLE, status = 0
WARNING: Runtime device already in DFU state ?!?
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0800
bytes_per_hash=604
Starting download: [##################################################] finished!
state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present
Done!
can't detach: error sending control message: Broken pipe
Resetting USB to switch back to runtime mode
$ lsusb
Bus 001 Device 051: ID 1fc9:0009
$ export CRT_DEBUG_TRACE=1
$ ./crt_emu_lpc11_13_nxp -info-emu -wire=winusb
Ni: LPCXpresso Debug Driver v4.0 (Mar 25 2012 14:25:38)
0 Emulators available:
I think, that dfu-util fails booting the debugger firmware, but why and what can I do to get it running again?
Kind regards
Stephan
