Content originally posted in LPCWare by im105 on Wed Sep 04 03:12:09 MST 2013
I'm using LPCXpresso LPC1769 board. I was running a custom program using TTC scheduler successfully. After adding WDT task using library functions of "lpc17xx_wdt.c" I got the following error when I debug my code.
15: Target error from Register access: Em(12). System rejected access at location 0x0304FFFD - verify Population of memory and peripherals
The code is building successfully but when I start debug then I got above error at the end (at 97%). Now my LPCXpresso LPC1769 board is not loading any other programs! I am stuck with this problem... Please guide me if you have any suggest.
I look forward for your help.
Many thanks,
MIR
