Content originally posted in LPCWare by CodeRedSupport on Tue Sep 14 14:46:58 MST 2010
Quote: jgold
That did not fix it. If anything, things are worse now.
The FAQ I pointed you at largely is focussed on explaining optimisation, so it is not immediately clear as to exactly *what* did not fix it. Can you clarify exactly what you did?
Quote:
I am getting build errors where none existed before, even in modules I can not access.
What build errors are you actually encountering?
I suggest that you try doing a clean of your project, then build it again. Then copy'n'paste the build log out of the IDE into this thread.
CodeRedSupport
