Content originally posted in LPCWare by ehughes on Sat Jan 22 06:58:26 MST 2011
A Couple questions/comments:
1.) It seems that the MSD does not work with Windows 7 64 bit. Everything seems to enumerate correctly with Windows XP 32-bit (both CDC and MSD). Working drivers, etc for Windows 7 64-bit would be great!
2.) When I use Windows XP, it looks like the COM port is detected (COM25) but I get an error "Unable to Open COM25, Please check you port settings" when I try to open the port in HyperTerminal. I tried different baud rates, etc and nothing seemed to work. I am trying to do a loopback on the LPCxpresso board (TXD to RXD)
3.) Does this forum support searching? I could not find a search link.
Thanks!
