Debug restart?
Debug restart?
lpcware
Content originally posted in LPCWare by woodchuck on Mon Aug 16 13:45:55 MST 2010
Can a debug session be restarted without rewriting FLASH?
lpcware
Content originally posted in LPCWare by CodeRedSupport on Mon Aug 16 15:43:47 MST 2010
If your project doesn't rebuild, the image file doesn't change. The flash programmer verifies the image file against the contents of flash. It won't reprogram your flash unless it finds a mismatch.
CodeRedSupport
