Content originally posted in LPCWare by affonpign on Wed May 25 03:55:31 MST 2011
Hi everybody,
I use the LPC1769 and I assign the external interrupt 3 to the GPIO using void EINT3_IRQHandler(void). Everything works fine. Is it possible to use the GPIO with the external interrupt 0,1 or 2 ?
I found this note in the datasheet:
Note: EINT3 channel is shared with GPIO interrupts
Does anyone have an example using external interrupts 0,1 or 2?
affonpign
