Content originally posted in LPCWare by lpcxpresso-support on Thu Sep 03 17:23:38 MST 2015
The LPCXpresso flash drivers use the IAP services offered within the bootloader. You'll find documentation of the IAP in the user manual. If your firmware performs in application program/erase/verify of flash, it would use these same services.
Thanks and regards,
LPCXpresso Support
