Content originally posted in LPCWare by kcarolan on Thu Apr 24 18:56:34 MST 2014
I am using the Lpc11e14 and I need to create a few variable the will not get initialized when I come out of reset. I am putting the Lpc11e14 to sleep and using the WDT to bring the Lpx11exx out of sleep. I would like to keep the variables intact when I come out of sleep. I did a search on un-initialized variable in lpcxpresso and found the following but I could not get it to compile.
volatile int32 __attribute__ ((section(“.noinit”))) variable;
Thanks, Kevin
