GROUP(libcr_semihost.a libcr_c.a libcr_eabihelpers.a)
MEMORY
/* Define each memory region */
BootFlash24 (rx) : ORIGIN = 0x0, LENGTH = 0x6000 /* 24K bytes */
MFlash232 (rx) : ORIGIN = 0x6000, LENGTH = 0x3a000 /* 232K bytes */
Ram0_16_32_36 (rwx) : ORIGIN = 0x02000000, LENGTH = 0x9000 /* 36K bytes */
/* Define a symbol for the top of each memory region */
__top_MFlash232 = 0x6000 + 0x0003a000;
__top_BootFlash24 = 0x0 + 0x6000;
__top_Ram0_16_32_36 = 0x2000000 + 0x9000;
ENTRY(ResetISR)
SECTIONS
.boot_vector : ALIGN(4)
FILL(0xFFFF)
KEEP(*(.boot_vector))
. = ALIGN(0x40);
KEEP(*(.debug_boot_id))
KEEP(*(.boot_redirects))
KEEP(*(.debug_boot_data))
} > BootFlash24
/* MAIN TEXT SECTION */
.text : ALIGN(4)
FILL(0xff)
__vectors_start__ = ABSOLUTE(.) ;
KEEP(*(.isr_vector))
/* Global Section Table */
. = ALIGN(4);
__section_table_start = .;
__data_section_table = .;
LONG(LOADADDR(.data));
LONG( ADDR(.data));
LONG( SIZEOF(.data));
__data_section_table_end = .;
__bss_section_table = .;
LONG( ADDR(.bss));
LONG( SIZEOF(.bss));
__bss_section_table_end = .;
__section_table_end = . ;
/* End of Global Section Table */
*(.after_vectors*)
} >MFlash232
.text : ALIGN(4)
*(.text*)
*(.rodata .rodata.* .constdata .constdata.*)
. = ALIGN(4);
} > MFlash232
* for exception handling/unwind - some Newlib functions (in common
* with C++ and STDC++) use this.
.ARM.extab : ALIGN(4)
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > MFlash232
__exidx_start = .;
.ARM.exidx : ALIGN(4)
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > MFlash232
__exidx_end = .;
_etext = .;
/* MAIN DATA SECTION */
.uninit_RESERVED : ALIGN(4)
KEEP(*(.bss.$RESERVED*))
. = ALIGN(4) ;
_end_uninit_RESERVED = .;
} > Ram0_16_32_36
/* Main DATA section (Ram0_16_32_36) */
.data : ALIGN(4)
FILL(0xff)
_data = . ;
*(vtable)
*(.ramfunc*)
*(.data*)
. = ALIGN(4) ;
_edata = . ;
} > Ram0_16_32_36 AT>MFlash232
/* MAIN BSS SECTION */
.bss : ALIGN(4)
_bss = .;
*(.bss*)
*(COMMON)
. = ALIGN(4) ;
_ebss = .;
PROVIDE(end = .);
} > Ram0_16_32_36
/* DEFAULT NOINIT SECTION */
.noinit (NOLOAD): ALIGN(4)
_noinit = .;
*(.noinit*)
. = ALIGN(4) ;
_end_noinit = .;
} > Ram0_16_32_36
PROVIDE(_pvHeapStart = DEFINED(__user_heap_base) ? __user_heap_base : .);
PROVIDE(_vStackTop = DEFINED(__user_stack_top) ? __user_stack_top : __top_Ram0_16_32_36 - 64);
