Content originally posted in LPCWare by szempy on Wed Feb 13 08:58:17 MST 2013
Quote: CodeRedSupport
It does look like your workspace is corrupted. It looks like you tried to close either Project Explorer, or the whole IDE earlier today, and it failed, whihc has caused a problem.
I would suggest selecting all of your projects and Exporting them. Then create a new Workspace and Import the projects that you just exported.
Thank you, that was probably the problem that i closed the IDE and corrupted the workspace.
