Content originally posted in LPCWare by R2D2 on Tue May 21 03:48:37 MST 2013
Quote: tbelo
So the normal application code will be called from the WAKEUP_IRQHandler.
Is that OK ?
Yes, then you can detect the source of the start as described above.
Quote: tbelo
Also about monitoring deep-sleep mode do you think ordering an oscilloscope is mandatory?
I'm not sure what 'dfv' is and which distributors are available there, but even a simple 'cheap' DSO is very useful to find problems and understand what's happening.
