#define CAN1_CTRL((uint8_t)(0)) #define CAN2_CTRL((uint8_t)(1)) |
void CAN_SetupAFTable(void) { FullCAN_Table[0].controller = CAN1_CTRL; FullCAN_Table[0].disable = MSG_DISABLE; FullCAN_Table[0].id_11 = 0x01; FullCAN_Table[1].controller = CAN1_CTRL; FullCAN_Table[1].disable = MSG_DISABLE; FullCAN_Table[1].id_11 = 0x02; FullCAN_Table[2].controller = CAN1_CTRL; FullCAN_Table[2].disable = MSG_DISABLE; FullCAN_Table[2].id_11 = 0x03; FullCAN_Table[3].controller = CAN1_CTRL; FullCAN_Table[3].disable = MSG_DISABLE; FullCAN_Table[3].id_11 = 0x06; FullCAN_Table[4].controller = CAN1_CTRL; FullCAN_Table[4].disable = MSG_DISABLE; FullCAN_Table[4].id_11 = 0x0C; FullCAN_Table[5].controller = CAN1_CTRL; FullCAN_Table[5].disable = MSG_DISABLE; FullCAN_Table[5].id_11 = 0x0D; SFF_Table[0].controller = CAN1_CTRL; SFF_Table[0].disable = MSG_DISABLE; SFF_Table[0].id_11 = 0x08; SFF_Table[1].controller = CAN1_CTRL; SFF_Table[1].disable = MSG_DISABLE; SFF_Table[1].id_11 = 0x09; SFF_Table[2].controller = CAN1_CTRL; SFF_Table[2].disable = MSG_DISABLE; SFF_Table[2].id_11 = 0x0A; SFF_Table[3].controller = CAN1_CTRL; SFF_Table[3].disable = MSG_DISABLE; SFF_Table[3].id_11 = 0x0B; SFF_Table[4].controller = CAN1_CTRL; SFF_Table[4].disable = MSG_DISABLE; SFF_Table[4].id_11 = 0x0E; SFF_Table[5].controller = CAN1_CTRL; SFF_Table[5].disable = MSG_DISABLE; SFF_Table[5].id_11 = 0x0F; // first acceptance filter for diagnostic tools SFF_GPR_Table[0].controller1 = SFF_GPR_Table[0].controller2 = CAN1_CTRL; SFF_GPR_Table[0].disable1 = SFF_GPR_Table[0].disable2 = MSG_DISABLE; SFF_GPR_Table[0].lowerID = 0x10; SFF_GPR_Table[0].upperID = 0x20; SFF_GPR_Table[1].controller1 = SFF_GPR_Table[1].controller2 = CAN1_CTRL; SFF_GPR_Table[1].disable1 = SFF_GPR_Table[1].disable2 = MSG_DISABLE; SFF_GPR_Table[1].lowerID = 0x20; SFF_GPR_Table[1].upperID = 0x25; SFF_GPR_Table[2].controller1 = SFF_GPR_Table[2].controller2 = CAN1_CTRL; SFF_GPR_Table[2].disable1 = SFF_GPR_Table[2].disable2 = MSG_DISABLE; SFF_GPR_Table[2].lowerID = 0x30; SFF_GPR_Table[2].upperID = 0x40; SFF_GPR_Table[3].controller1 = SFF_GPR_Table[3].controller2 = CAN1_CTRL; SFF_GPR_Table[3].disable1 = SFF_GPR_Table[3].disable2 = MSG_DISABLE; SFF_GPR_Table[3].lowerID = 0x40; SFF_GPR_Table[3].upperID = 0x50; SFF_GPR_Table[4].controller1 = SFF_GPR_Table[4].controller2 = CAN1_CTRL; SFF_GPR_Table[4].disable1 = SFF_GPR_Table[4].disable2 = MSG_DISABLE; SFF_GPR_Table[4].lowerID = 0x50; SFF_GPR_Table[4].upperID = 0x60; SFF_GPR_Table[5].controller1 = SFF_GPR_Table[5].controller2 = CAN1_CTRL; SFF_GPR_Table[5].disable1 = SFF_GPR_Table[5].disable2 = MSG_ENABLE; SFF_GPR_Table[5].lowerID = 0x7E8; SFF_GPR_Table[5].upperID = 0x7EF; EFF_Table[0].controller = CAN1_CTRL; EFF_Table[0].ID_29 = (1 << 11); EFF_Table[1].controller = CAN1_CTRL; EFF_Table[1].ID_29 = (2 << 11); EFF_Table[2].controller = CAN1_CTRL; EFF_Table[2].ID_29 = (3 << 11); EFF_Table[3].controller = CAN1_CTRL; EFF_Table[3].ID_29 = (4 << 11); EFF_Table[4].controller = CAN1_CTRL; EFF_Table[4].ID_29 = (0x0e << 11); EFF_Table[5].controller = CAN1_CTRL; EFF_Table[5].ID_29 = (0x0f << 11); EFF_GPR_Table[0].controller1 = EFF_GPR_Table[0].controller2 = CAN1_CTRL; EFF_GPR_Table[0].lowerEID = (5 << 11); EFF_GPR_Table[0].upperEID = (6 << 11); EFF_GPR_Table[1].controller1 = EFF_GPR_Table[1].controller2 = CAN1_CTRL; EFF_GPR_Table[1].lowerEID = (7 << 11); EFF_GPR_Table[1].upperEID = (8 << 11); EFF_GPR_Table[2].controller1 = EFF_GPR_Table[2].controller2 = CAN1_CTRL; EFF_GPR_Table[2].lowerEID = (9 << 11); EFF_GPR_Table[2].upperEID = (0x0a << 11); EFF_GPR_Table[3].controller1 = EFF_GPR_Table[3].controller2 = CAN1_CTRL; EFF_GPR_Table[3].lowerEID = (0x0b << 11); EFF_GPR_Table[3].upperEID = (0x0c << 11); EFF_GPR_Table[4].controller1 = EFF_GPR_Table[4].controller2 = CAN1_CTRL; EFF_GPR_Table[4].lowerEID = (0x11 << 11); EFF_GPR_Table[4].upperEID = (0x12 << 11); EFF_GPR_Table[5].controller1 = EFF_GPR_Table[5].controller2 = CAN1_CTRL; EFF_GPR_Table[5].lowerEID = (0x13 << 11); EFF_GPR_Table[5].upperEID = (0x14 << 11); AFTable.FullCAN_Sec = &FullCAN_Table[0]; AFTable.FC_NumEntry = 6; AFTable.SFF_Sec = &SFF_Table[0]; AFTable.SFF_NumEntry = 6; AFTable.SFF_GPR_Sec = &SFF_GPR_Table[0]; AFTable.SFF_GPR_NumEntry = 6; AFTable.EFF_Sec = &EFF_Table[0]; AFTable.EFF_NumEntry = 6; AFTable.EFF_GPR_Sec = &EFF_GPR_Table[0]; AFTable.EFF_GPR_NumEntry = 6; } void init_can(void) { PINSEL_CFG_Type PinCfg; //Pins PINSEL_ConfigPin((PINSEL_CFG_Type *) &can_rd1_pin); PINSEL_ConfigPin((PINSEL_CFG_Type *) &can_td1_pin); // p1.31 Select input // Select lo = high speed = normal // Select hi = silent mode = tx disabled PinCfg.Funcnum = 0; PinCfg.Portnum = 1; PinCfg.Pinnum = 31; PINSEL_ConfigPin(&PinCfg); GPIO_SetDir( 0, 1<<31, 1);// output GPIO_ClearValue(0, 1<<31);// low //Initialize CAN1 baudrate CAN_Init(LPC_CAN1, 500000); //Enable Receive Interrupt CAN_IRQCmd(LPC_CAN1, CANINT_FCE, ENABLE); CAN_IRQCmd(LPC_CAN1, CANINT_RIE, ENABLE); CAN_IRQCmd(LPC_CAN1, CANINT_DOIE, ENABLE); CAN_SetupCBS(CANINT_FCE, CAN_Callback0); CAN_SetupCBS(CANINT_RIE, CAN_Callback1); CAN_SetupCBS(CANINT_DOIE, CAN_Callback2); //CAN_IRQCmd(LPC_CAN1, CANINT_TIE1, ENABLE); CAN_ModeConfig( LPC_CAN1, CAN_OPERATING_MODE, ENABLE); // Set up acceptance filter CAN_SetupAFTable(); CAN_ERROR er; er = CAN_SetupAFLUT(LPC_CANAF, &AFTable); CAN_SetAFMode(LPC_CANAF,CAN_Normal); //Enable CAN Interrupt NVIC_EnableIRQ(CAN_IRQn); } |
