Content originally posted in LPCWare by black_ghost on Fri Oct 14 16:23:51 MST 2011
Quote: whitecoe
Sorry, I just have to ask - have you actually looked at any of the code provided along with LPCXpresso IDE????
There are several that make use of the sys tick timer that would show you exactly how to set this up, and to use it to create a delay loop.
I looked and couldnt find any example. the only example i came across was based on LPC1768 and not LPC1769. i imported the project and couldnt compile it on LPC1769. I am trying to use systick as a time delay to drive a 16x2 lcd using a 4bit interface. If you have an idea that would really help thanks.
