Content originally posted in LPCWare by ex-kayoda on Fri Nov 16 04:37:42 MST 2012
Quote: Aamir Ali
What is purpose of above.
What's not clear there :confused:
XTALIN is an input ;)
UM10524:
Quote:
When the system oscillator is not used, connect XTALIN and XTALOUT as follows: XTALIN can be left floating or can be grounded (grounding is preferred to reduce susceptibility to noise). XTALOUT should be left floating.
