Content originally posted in LPCWare by TheFallGuy on Tue Sep 17 01:43:25 MST 2013
The .axf file is not being deleted - it is not being created!
You must fix your linker error first. The error means that you application is too big for the RamLoc32 memory region. Use forum search to find why this might have happened
