lpcware
fedora19 lpcxpresso error
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by mattes on Tue Jan 28 10:01:23 MST 2014
just tried to run the lpcxpresso on Fedora 19.
$ /usr/local/lpcxpresso_6.1.4_194/lpcxpresso/lpcxpresso
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x4596b1be, pid=1706, tid=3077756608
# JRE version: 7.0_25-b30
# Java VM: OpenJDK Client VM (23.7-b01 mixed mode linux-x86 )
# Problematic frame:
# C  [libsoup-2.4.so.1+0x561be]  soup_session_feature_detach+0x1e
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/mattes/hs_err_pid1706.log
# If you would like to submit a bug report, please include
# instructions on how to reproduce the bug and visit:
#   https://bugs.launchpad.net/ubuntu/+source/openjdk-7/
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted (core dumped)
I updated Fedora 19 to the latest (yum update) and it still behaves the same way.
Installed lpcxpresson from scratch.
On start it comes up with the initial lpcxpresso screen and sets up the working directory and
then it folds.
it crashes with a libsoup error
is there a fix available for this?
Does any other lpcxpresson version to work under Fedora 19?
mat
Original Attachment has been moved to: hs_err_pid1706.log_.txt.zip
