Content originally posted in LPCWare by Luis Digital on Tue Sep 21 15:53:21 MST 2010
Hello CodeRed,
I found a few examples do not work because the file name is misspelled. Remember that the file system is case sensitive:
"lpc13xx.h" The correct name is: "LPC13xx.h"
[COLOR=#000000]I also found problems for links:
"cannot open linker script file ../ld/usb_buffer_lib.ld : No such file or directory usbhid_rom"
[/COLOR]I also found some white space at the end of a path, file: "usb_buffer.ld" in "usbmsd_rom".
[COLOR=#000000]
[/COLOR]
